How to create a module
Silencio's avatar
Silencio
18 years ago
Silencio's avatar Silencio
I’m new to EE and I would like to add more features in the control panel than are available.
Does anyone know of any tutorials on how to create modules?
Thanks.
[Moderator Edit: Moved to Modules forum]
silenz's avatar
silenz
18 years ago
silenz's avatar silenz
The official docs were actually a good starting point for me.
Leevi Graham's avatar
Leevi Graham
18 years ago
I just released my first module which has full commented code (http://leevigraham.com/ee-support/expression-engine-social-bookmarks-module/).
I also found the docs very helpful.
The one thing I had trouble with was the replacement of tags in the template. Once I figured out that a string was being passed into the method and that the main thing you do is replace parts of the string with values using regular expressions and replace methods I was on my way.
