freeform form creation
Lynn F's avatar
Lynn F
18 years ago
Lynn F's avatar Lynn F
another newbie question. How do you create a freeform form? I’ve made up a form, run it, it doesn’t show up in my freeform forms list, it is missing a field (which is probably because freeform didn’t formerly create the form in the first place.
Ingmar's avatar
18 years ago
Ingmar's avatar Ingmar
You need to create all the fields that you are going to use, the form as such will be created the first time you use it.
On a related note, may I point out www.solspace.com/forums/ for your Solspace support issues? (Disclaimer: I am an admin there.)
Lynn F's avatar
Lynn F
18 years ago
Thanks for your reply. I noticed you have written about formhelper. Where do I find that?
Lynn F's avatar
Lynn F
18 years ago
where do I create the fields?
Ingmar's avatar
18 years ago
Formhelper is another Solspace plugin. Serves a slightly different purpose, though. Freeform fields are created through the module’s control panel.
Lynn F's avatar
Lynn F
18 years ago
perhaps that’s my problem at this point. Where is the freeform control panel located?
Lynn F's avatar
Lynn F
18 years ago
got it Ingmar, it was a matter of putting the pieces together.
