slideshow module?
shefinds's avatar
shefinds
19 years ago
shefinds's avatar shefinds
I want to be able to embed slideshows into blog posts – is there a module that does this? the ui needs to be really easy to build it because I’m going to have some writers do it.
Stephen Slater's avatar
Stephen Slater
19 years ago
Stephen Slater's avatar Stephen Slater
5pieces has written a couple tutorials based around SlideShow Pro and Mono Slideshow.
Also, you could build your own around any number of methods using EE’s Gallery module.
shefinds's avatar
shefinds
19 years ago
thanks – but what I want is something that has text and photos in the slideshow. these seem to just have photos. also the workaround methods for ee’s gallery make it realy difficult for a non-techie to use. i want something that’s plug and play.ideas?
Stephen Slater
19 years ago
Both SlideShowPro and Mono Slideshow enable you to have captions. Are captions for each photo what you want? Typically captions are a sentence or two about the photo.
Another option is to set up a weblog with custom fields and have EE “feed” a custom solution. You could start with something like this javascript in your EE template(s) and then let custom weblog fields handle the rest. Once this is set-up, your writers couldn’t have it any easier. They will just use EE’s control panel or a SAEF prepared for slideshow management.
It really doesn’t get any better than that since those options are so good and solid. A “plug and play” module, like you find with many of the popular open source CMS’s, probably isn’t available with EE (that I am aware of). EE’s approach is slightly different and more flexible. Again, once the weblogs are set up to manage a slideshow, I’m sure your writers will find it very easy to manage.
I hope this was helpful.custom weblog fieldscustom weblog fields
laurentsj's avatar
laurentsj
18 years ago
laurentsj's avatar laurentsj
Stephen,
i see you’ve been using using SmoothGallery ?
When we just finished implementing a way of posting monoslideshow just by ftp-ing jpegs, and entering a unique name in a custom field, i find SmoothGallery to be a lot more SEO friendly and probably lighter.
Any more tips on how difficult it was to implement this ?
L
