Repeet Daylight Saving Time Bugs
Mr. Wilson's avatar
Mr. Wilson
19 years ago
Mr. Wilson's avatar Mr. Wilson
I have found one Daylight Saving Time-related bug in Repeet, and there may be others hiding away, waiting to be discovered. If you run across any odd behaviors that you think could possibly be related to DST, please post the details here. For debugging purposes, it would help me tremendously if you would post:
  1. The item’s start date/time
  2. The item’s end date/time (if any)
  3. The item’s repeat interval
  4. Any include/exclude dates
  5. Any other details you think might be relevant.
I don’t have the time or resources to support more than the current version of Repeet, so if you aren’t on version 1.0.5, please first download and install the latest version to see if that takes care of the problem. Thanks!
the wire's avatar
the wire
18 years ago
the wire's avatar the wire
Running 1.0.5 and having trouble with DST. Would greatly appreciate your thoughts
e.g. http://www.templeemanuel.ca/index.php/calendar/cat/worship_services/
start time: 2007-06-01 07:30 AM end time: 2007-12-31 08:00 AM repeat interval: days of the week:1,2,3,4,5 no include dates no exclude dates other info: EE is set up do not honor the DST setting associated with each section entry
Starting from November 5th the event is displayed like starting at 06:30 and ending at 07:00.
Same happens with all repeating events. Non-repeating events are properly displayed.
If any further details would help shed light on this please let us know.
Gabriela thewire.ca
Mr. Wilson's avatar
Mr. Wilson
18 years ago
the wire: Check your PM inbox.
