active directory integration
Seamus's avatar
Seamus
19 years ago
Seamus's avatar Seamus
Is it possible to integrate EE login with active directory? I am considering bidding on an enterprise level site that would like to provide their existing active directory database with logins to an EE powered site. Saw some rumblings awhile ago about LDAP integrationa and found this:
http://adldap.sourceforge.net/
ExpressionEngineer's avatar
ExpressionEngineer
19 years ago
ExpressionEngineer's avatar ExpressionEngineer
Since EE v1.4.2 there is a hook called login_authenticate_start in the authenticate() function in cp.login.php.
I’ve used that hook a while back to handle this scenario in a small Extension: 1. authenticate username and password in AD LDAP. 2. if successful and username doesn’t exist in EE - add the member - otherwise skip to #3 3. login to EE
..of course, there are about a zillion other possible needs, but this is all I’ve had to produce.
edit: I vaguely remember having to hack something, but I can’t remember what is was, or if it was vital or just extra fluff
Seamus's avatar
Seamus
19 years ago
That’s all I needed to know. Thanks!
spasmoid's avatar
spasmoid
18 years ago
spasmoid's avatar spasmoid
Since EE v1.4.2 there is a hook called login_authenticate_start in the authenticate() function in cp.login.php. I’ve used that hook a while back to handle this scenario in a small Extension: 1. authenticate username and password in AD LDAP. 2. if successful and username doesn’t exist in EE - add the member - otherwise skip to #3 3. login to EE ..of course, there are about a zillion other possible needs, but this is all I’ve had to produce. edit: I vaguely remember having to hack something, but I can’t remember what is was, or if it was vital or just extra fluff
If you could provide us with some code, we would be grateful.
Brent Cartier's avatar
Brent Cartier
18 years ago
Brent Cartier's avatar Brent Cartier
Hi ExpressionEngineer,
It seems that there’s a lot of interest on the forums looking for any kind of LDAP extension.
Would you be interested in selling a version of your extension for EE 1.6.3? If so, I know I’d buy today. I realize it won’t/can’t meet everyone’s specific LDAP requirements, but it sounds like a great start.
Thanks for your time,
b
