Weathericon km/h
Per's avatar
Per
19 years ago
Per's avatar Per
I installed the WeatherIcon plugin. I am trying to convert the ‘Measurement for wind speed’ from miles per hour to kilometers per hour. It just returns INVALID DATA
Used ‘wind_unit=”km/h”’: as suggested in the OPTIONAL - UNITS description of the plugin. Is there someone who has the WIND (speed) displayed in km/h succesfully? (Miles per hour works just fine).
Thanks in advance, Piedro
{exp:weathericon station=”EHRD” heading=”Weather” display_icon=”yes”
display_temperature=”yes” display_heat_index=”no” display_wind_chill=”no” display_humidity=”no” display_wind=”yes” display_dew_point=”no” display_barometer=”no” display_clouds=”yes” display_conditions=”yes” display_visibility=”no”
icon_width=”80” icon_height=”80” icon_location=”images/wicons” icon_extension=”.png” temperature=”C” debug_conditions=”false” wind_unit=”km/h” sunrise_hour=”7” sunset_hour=”18”
debug_cache=”false” }
Lisa Wess's avatar
19 years ago
Lisa Wess's avatar Lisa Wess
Hi, Piedro – Since this is a third party plugin, I’m going to move this over to the plugins forum for you to get some help with it. If you don’t hear anything here it might be worth trying to contact the author directly, as well.
Per's avatar
Per
19 years ago
Per's avatar Per
Sorry and thank you.
Piedro
seth.aldridge's avatar
seth.aldridge
18 years ago
seth.aldridge's avatar seth.aldridge
Would anyone be able to retool this to be AJAX based and have the ability to enter a Zip Code??? It would be extremely useful for a project I’m working on.
