spam prevention and form encoder
Sean C. Smith's avatar
Sean C. Smith
19 years ago
Sean C. Smith's avatar Sean C. Smith
two new extensions on the developer blog. I downloaded them and there are files that I don’t konw where to put them.
._lang.comment_spam_prevention.php ._ext.form_tag_encoder.php ._ext.comment_spam_prevention.php
all of these files appear to be duplicates of other files without the ._ prefix
What do I do with them.
Peter E's avatar
Peter E
19 years ago
Peter E's avatar Peter E
two new extensions on the developer blog. I downloaded them and there are files that I don’t konw where to put them. ._lang.comment_spam_prevention.php ._ext.form_tag_encoder.php ._ext.comment_spam_prevention.php all of these files appear to be duplicates of other files without the ._ prefix What do I do with them.
They’re Mac OS X file system clutter. Ignore them.
Sean C. Smith
19 years ago
I just noticed a problem with the form tag encoder plugin. I tried to view a member profile and got the following error.
Fatal error: Call to a member function parse_globals() on a non-object in /path/to/system/extensions/ext.form_tag_encoder.php on line 182
Paul Burdick's avatar
Paul Burdick
19 years ago
Paul Burdick's avatar Paul Burdick
Download the extension again and replace. Seems there is a usage of the $FNS->form_declaration() method in the member stuff that I forgot about.
Sean C. Smith
19 years ago
thanks that fixed the problem.
Sean C. Smith
19 years ago
Another problem has come to my attention. I found out that my site was broken in IE and determined it was due to the form encoder extension. Site is unbroken after disabling the extension. I got a number of run-time errors if that will help with debugging.
DEA's avatar
DEA
18 years ago
DEA's avatar DEA
I am now coming across the very same issue. Was a resolution ever provided?
Derek Jones's avatar
Derek Jones
18 years ago
Download and replace your current extension, DEA, so you can be sure you are running the most current. If that does not fix it, please provide details on the errors and how / where to reproduce them.
