Solspace's FreeForm - Default template lock
G - B - O's avatar
G - B - O
19 years ago
G - B - O's avatar G - B - O
Hi there,
First, FreeForm is a great module! But when i want to edit my templates, the default one is “locked”. Only if i change
C=modules&M=freeform&P=edit_template_form&template_id=2
to
C=modules&M=freeform&P=edit_template_form&template_id=1
It appears not to be locked at all.
Solspace's avatar
Solspace
19 years ago
Solspace's avatar Solspace
Nice hack! 😊 Very tricky.
mk
manuqc's avatar
manuqc
16 years ago
manuqc's avatar manuqc
hi G - B - O, I was asking myselft about that,but where exactly do you change that? thanks.
G - B - O's avatar
G - B - O
16 years ago
Very easy; i just altered the URL that appears in the addressbar of the browser. You only set the template_id variable to ‘1’.
Gabriel's avatar
Gabriel
16 years ago
Gabriel's avatar Gabriel
Not clever. Do not edit default locked template. After upgrade with newer Freeform version will be this template reset and all template data lost. It’s my personal experience. After that I never touched on default template 😉
I’m not sure, why Freeform upgrade script overwrite default template and why is this template locked.
