Is there a no/low-code way to move entries from one channel to another?
User VWDN4ePj's avatar
User VWDN4ePj
3 months ago
User VWDN4ePj's avatar User VWDN4ePj
Russ K.'s avatar
Russ K.
3 months ago
Russ K.'s avatar Russ K.
as long as the channels have the same fields, you can do it from the “Options” tab
Russ K.'s avatar
Russ K.
3 months ago
Instead of the just the one channel it will show 2 (or however many channels match). But if even one field is missing from the alternate channel I don’t think you’ll see the option.
User VWDN4ePj
3 months ago
The channel I want to move entries to has all the same fields, but still not seeing it populate in that radio list. Is there something else I need to do?
User VWDN4ePj
3 months ago
Oh I see…both have to have to share all the fields. Much appreciated!
Russ K.'s avatar
Russ K.
3 months ago
Hop Studios's avatar
Hop Studios
3 months ago
Hop Studios's avatar Hop Studios
And the same category groups.
