Do WebP manipulation supports transparent PNG formats in EE?
chunkitchris's avatar
chunkitchris
one week ago
chunkitchris's avatar chunkitchris
I would like to know if EE WebP manipulation supports transparent PNG formats. It does not work on our site, and I’m not sure if I missed something on my end.
User BULfYYMv's avatar
User BULfYYMv
one week ago
User BULfYYMv's avatar User BULfYYMv
It does, but I think it might depend on your environment.
User BULfYYMv
one week ago
it works for me in ddev (locally) and in cloudways hosting.
chunkitchris
one week ago
do you mean our server?
User BULfYYMv
one week ago
Yes
chunkitchris
one week ago
But why can’t it run on our server? Thanks for confirming. I’ll try again.
User BULfYYMv
one week ago
I can’t remember what image library it relies on… but I’m sure that it’s like Imagick or something like that. Each host may have slightly different configurations for it.
jelle's avatar
jelle
one week ago
jelle's avatar jelle
try jcogs img
JCOGS Design's avatar
JCOGS Design
one week ago
It might be a version issue with EE. It is not the first time this has come up, and I’m pretty sure that at some point in the recent-ish past EE’s image processing workflow had a defect (where it converted things to jpg before converting to wepb, losing transparency as a result, if I recall rightly); but I think that was fixed a while back.
But @Jelle / ee-websites.eu / Silver partner is right … for all sorts of very good reasons you should use JCOGS Image Pro for such conversions
User XLYiWdAt's avatar
User XLYiWdAt
6 days ago
User XLYiWdAt's avatar User XLYiWdAt
There is a pr for a fix that might help. https://github.com/ExpressionEngine/ExpressionEngine/pull/5069
