Skill for Claude Code to help with addon development?
User BULfYYMv's avatar
User BULfYYMv
4 months ago
User BULfYYMv's avatar User BULfYYMv
Anyone else try making a skill for Claude Code to help with addon development?
4 months ago
MCP (yet to be released)… does wonders on this front..
User BULfYYMv
4 months ago
Claude seems to have trouble looking at the ExpressionEngine docs (even if I provide specific URLs).
User BULfYYMv
4 months ago
And Claude doesn’t seem to want to use the CLI for addon scaffolding.
User BULfYYMv
4 months ago
Also annoying
4 months ago
context 7 helps a lot with docs.
User l1NJX8FJ's avatar
User l1NJX8FJ
4 months ago
User l1NJX8FJ's avatar User l1NJX8FJ
I have some positive results by first reading/skimming the docs myself. Then I used the EE CLI to create the initial layout of the add-on. AI tends to get messy if you let it bootstrap the entire project even with context. Finally, I used Cursor MCP -> context7 with Sonnet 4.5 (model) or Gemini 3.
User 1DlbpEFnC's avatar
User 1DlbpEFnC
4 months ago
User 1DlbpEFnC's avatar User 1DlbpEFnC
Was able to create the skeleton for an add-on using a Claude DDEV helper command (which Claude was more than happy to write for me).
4 months ago
So we’ve been making some solid progress on the MCP. We’ve decided to do beta, but we’re looking to keep the group pretty small initially, until we have everything ironed out. If your interested in joining the beta! 😄
User l1NJX8FJ
4 months ago
Sounds cool!
User rv9wJQQk's avatar
User rv9wJQQk
about 3 months ago
User rv9wJQQk's avatar User rv9wJQQk
@tomjaeger i filled out the form would be keen to get into the beta if possible still
