Charge update from 4.1.1 to 4.4.1
strudel's avatar
strudel
one month ago
strudel's avatar strudel
I’m updating Charge on my site from 4.1.1 to 4.4.1 and I’m not finding the documentation very clear since I’m an idiot. It says to “Copy /charge/ to /system/user/addons/” and “Copy /themes/charge/ to /themes/user/charge/” - all fine there - but what do I do with the other things in the download, like the templates and charge_assets folders and package.json and phpcs.xml?
one month ago
you can ignore them
Rob Allen's avatar
Rob Allen
one month ago
Rob Allen's avatar Rob Allen
You can ignore the extra stuff. When I last used it the templates folder contained an example template group+templates with examples/tags you can use and I think from memory the charge_assets folder are assets used by the example templates. That may have changed!
strudel's avatar
strudel
one month ago
Thanks! Maybe I’m just overly cautious….
one month ago
yup.. thats correct! Its a pretty good example set of templates for the 10 ish things people like to do with Charge.. to help them get started quicker
