Pro Search won't disable with Transcribe
User A62fOcsj's avatar
User A62fOcsj
one month ago
User A62fOcsj's avatar User A62fOcsj
I’m wondering if I’m missing something in the documentation regarding using Transcribe with Pro Search.
On an older site running EE 3.5.4 with Transcribe 2.2.2 and Low Search 5.0.5, I was able to add **transcribe=”disable” ** as a parameter in exp:low_search:results to pull the default entry content into the results instead of the translated version.
Now I’m working on an EE 7 site with Transcribe 3.13.4 and Pro Search, and I’m wondering if there’s a more modern or recommended way to accomplish the same thing. As this is no longer working. Or is there a way for Transcribe to ignore a channel completely?
Has the approach changed, or is there an equivalent parameter/workflow I should be using?
one month ago
oh interesting.. there is a new search integration that does it at a more fundamental level with Pro Search.
User A62fOcsj
one month ago
In a perfect world we would have other entries associated for the different languages, its just not how we built it back then. It was 1 product master entry that had pricing, images, titles and sku’s, we didn’t see the need to duplicate and manage that content across different languages. And transcribe=”disable” did the trick.
User A62fOcsj
one month ago
@tomjaeger is that new search integration something that is available now?
one month ago
if your on the new version.. its likely running it currently
one month ago
(trying to see if the transcribe=”disable” is a regression currently)
User A62fOcsj
one month ago
thanks. in the Transcribe docs it says that it will be removed on version 4
one month ago
can you link me to that?
User A62fOcsj
one month ago
Transcribe Disable
User A62fOcsj
one month ago
I figured if we were on version 3.13.4 we’d be good! 😉
one month ago
yes.. looks like a regression in the search filter that it doesn’t actually respect the disable.
one month ago
I’ll drop you a new version of it shortly here
User A62fOcsj
one month ago
Awesome!
one month ago
for people following along.. this has been resolved and a patched version has been released
User A62fOcsj
one month ago
Thanks Tom! The solution worked!
