Will DataGrab update the url_title of an entry if it was updated in the import?
Josh Conner's avatar
Josh Conner
5 months ago
Josh Conner's avatar Josh Conner
Does anyone know if DataGrab will update the url_title of an entry if it was updated in the import file? I have the url_title set to a custom field from the import file but it doesn’t seem to update the entry in EE.
User BULfYYMv's avatar
User BULfYYMv
5 months ago
User BULfYYMv's avatar User BULfYYMv
If the url_title is used as the matching field it would likely create a new entry vs updating the old one.
Josh Conner
5 months ago
It isn’t, I am using a different different field that is a unique id for the matching field.
creativearc's avatar
creativearc
5 months ago
creativearc's avatar creativearc
GOod Q. I have a similar Q about author. Weird as it is, I might need to change an entry’s author based on the import. @litzinger?
creativearc
5 months ago
Wow, DG does update author on import. that’s rad. for me at least 😃
