Foolproof way to handle pagination for pro search results when you are using query strings?
User BULfYYMv's avatar
User BULfYYMv
5 months ago
User BULfYYMv's avatar User BULfYYMv
Anyone have a foolproof way to handle pagination for pro search results when you are using query strings?
User BULfYYMv
5 months ago
The issue is on the first page the url is search/results?keywords=keyword Every page after that is search/results/P10?keywords=keyword
So basically the query is moving from the 3rd segment to the 4th segment.
Rob Allen's avatar
Rob Allen
5 months ago
Rob Allen's avatar Rob Allen
In your results tag you could try query="{last_segment}"
NikiW's avatar
NikiW
5 months ago
NikiW's avatar NikiW
It’s making every page the P10? Maybe I don’t understand the issue? Is it not working at all?
User BULfYYMv
5 months ago
@roballen That’s too easy…
User BULfYYMv
5 months ago
So…it’ll probably work
NikiW's avatar
NikiW
5 months ago
@Jared does pagination break when it’s doing that for you? On the site where we have pagination + Pro search, our results URL is just /search?keywords=keyword, and the second page does similar as yours with /search/P10?keywords=keyword, but I don’t see anything amiss.
User BULfYYMv
5 months ago
Well darn. that didn’t work.
User BULfYYMv
5 months ago
Technically the pagination works, the thing that breaks is that pro search is not parsing the keywords query.
User BULfYYMv
5 months ago
Because the keywords query moves from the 3rd segment to the 4th segment.
User BULfYYMv
5 months ago
For whatever reason last_segment doesn’t work
NikiW's avatar
NikiW
5 months ago
So it’s… not keeping the results in the pages that are paginated beyond the first one?
On the site I looked at, with the URL I mentioned, the query in the results tag is on segment_2 - which is what the paginated results end up on in the URL. Maybe instead of last_segment, try segment_3?
User BULfYYMv
5 months ago
I did try that but it being a moving target is the problem. The site you are looking it, is it using encoded urls?
NikiW's avatar
NikiW
5 months ago
No.
NikiW's avatar
NikiW
5 months ago
it used to but I disabled it long before I added pagination.
1 2
