What to use for front-end builds?
User sqqnM5TM's avatar
User sqqnM5TM
2 months ago
User sqqnM5TM's avatar User sqqnM5TM
I’m wondering what people are using for front-end builds these days with EE. We’ve been using Laravel Mix for a few years but it looks like that’s being abandoned for Vite. I tried Vite but it doesn’t seem appropriate for EE projects. Anyone have recommendations for building CSS and JS with EE sites using Tailwindcss?
User iC5U2Ymh's avatar
User iC5U2Ymh
2 months ago
User iC5U2Ymh's avatar User iC5U2Ymh
We use Tailwind with Vite on the frontend, works great. We have an EE add-on that does the asset management in the template (no hot reloading yet).
User iC5U2Ymh
2 months ago
Allows for js and css, similar set up to Laravel (/resources/js and /resources/css)
User sqqnM5TM
2 months ago
I liked the look of Vite but couldn’t see how to get it working with EE. Also, monitoring changes to templates to trigger tailwind to recompile wasn’t obvious. I probably didn’t give it enough thought. Interested in how you’re doing it though.
creativearc's avatar
creativearc
2 months ago
creativearc's avatar creativearc
I feel old school by saying: none of the above
creativearc
2 months ago
¯\_(ツ)_/¯
User iC5U2Ymh
2 months ago
I’ll pull it together for you, give me a day or so
creativearc
2 months ago
we don’t use tailwind, or even bootstrap… we just roll our own HTML (with some starting points common to our builds)
User sqqnM5TM
2 months ago
Thanks @dougblackjr
User sqqnM5TM
2 months ago
@creativearc used to do that here. It’s temping to go back to the old school way!
User iC5U2Ymh
2 months ago
So we use @Stephen Galbraith’s add-on: https://github.com/nerdgency/ee-vitesse
And then, our vite.config and tailwind.config go in the document root. These assume that you are using a public folder, and do NOT have your system folder in the same folder according to the best practices.
User iC5U2Ymh
2 months ago
Then templates look like….
User iC5U2Ymh
2 months ago
<link rel="preload" href="{exp:vitesse:asset resource='resources/css/app.css'}" as="style" />
<link rel="stylesheet" href="{exp:vitesse:asset resource='resources/css/app.css'}" />
<link rel="preload" href="{exp:vitesse:asset resource='resources/css/fa.css'}" as="style" />
<link rel="stylesheet" href="{exp:vitesse:asset resource='resources/css/fa.css'}" />
User iC5U2Ymh
2 months ago
And this plugin does hot reloading
jelle's avatar
jelle
2 months ago
jelle's avatar jelle
Frontend… simple sites i still use Foundation, since it can be pretty light weight, and i’m used to the syntax. When it gets more complicated… i roll my own. straight up html/css/vanilla js or jquery. I’ve seen and used all that frontend crap over the years. No more SASS, LESS, SCSS, tailwind or any other halleluja frontend miracle framework (abandonware) for me. It should all be doable with a text editor, headbanging and the F5 key
1 2
