How to tell is a grid field is being used inside a relationship tag?
User z9NVFGOr's avatar
User z9NVFGOr
2 months ago
User z9NVFGOr's avatar User z9NVFGOr
This is probably a very easy one (it’s 6.30 on friday so I’m running on empty), but is there a consistent way to test if a grid field is being used inside a relationship tag - somethnig simple (in my case, if video show it if else image)
IE:
{relationship_field}
 {if relationship_field:grid_field_has_content}<!-- << what works here??? -->
  <!-- video code here -->
 {if:else}
  {relationship_field:image_file_field}
{/relationship_field}
User z9NVFGOr
2 months ago
I know it’s filthy but I have this working with an embed for now.
{relationship_field} {embed='inc/the_grid_stuff' embed_entry_id="{relationship_field:entry_id}"} {/relationship_field}
but I’m sure there’s a more performant way…?
Rob Allen's avatar
Rob Allen
2 months ago
Rob Allen's avatar Rob Allen
I have noticed a difference sometimes between {if my_grid} and {if mygrid != ""} - can’t say why this works/doesn’t work.
I have done similar to your solution using an embed, it works. On one site I had a relationship field referencing 5 entries in 7 different channels, and each entry had it’s own (complex) display requirements, an embed for each channel got it working and the overhead was minimal..
User z9NVFGOr
2 months ago
Thanks, I’ll try the latter, see if it works…
