How do I display total entry count while limiting entries shown?
User fRIQeIlu's avatar
User fRIQeIlu
5 months ago
User fRIQeIlu's avatar User fRIQeIlu
Is there a way to display the total count of entries for a channel while limiting the number of entries that is shown? I saw this posted online (below), but it doesn’t work.
{exp:channel:entries channel="news" limit="5"}
    {if count == 1}
     Total News Articles: {total_results}
    <div class="news-item">
     <h3>{title}</h3>
     {excerpt}
    </div>
So, in this case, I would want the total results to show like 20, but it currently says 5.
User jdvkpNCN's avatar
User jdvkpNCN
5 months ago
User jdvkpNCN's avatar User jdvkpNCN
Can’t see anything in the docs for the channel entries tag that returns the number of entries in the channel - which definitely feels like an omission. The right place for it might be in the {exp:channel:info} tag (as well as maybe in the channel entries tag).
A workaround might be to take out your limit attribute, so it returns the entire channel, and then use {absolute_results} as your value. (Not sure how {total_results} is different from that.)
Then, within the loop, you could use a comparison with {count} or {absolute_count} to limit what’s actually processed. It’s inefficient, obv., because it pulls the entire channel from the DB, but if it’s not a huge channel it would be okay.
Rob Allen's avatar
Rob Allen
5 months ago
Rob Allen's avatar Rob Allen
The Statistics module may help here (it should be installed by default):
{if count == 1} {exp:stats channel="news"} <p>Total news articles: {total_entries}</p> {/exp:stats} {/if}
User jdvkpNCN
5 months ago
@roballen Damn, missed that. 👍
Hop Studios's avatar
Hop Studios
5 months ago
Hop Studios's avatar Hop Studios
absolute_results will return what you’re looking for if you have pagination enabled. Without pagination it’s the same as the limit.
JCOGS Design's avatar
JCOGS Design
5 months ago
Put the whole of the channel entries into a layout array and save the count as part of that, then when you replay the layout array put in a limit of 5 to get the first five. e.g.
{exp:channel:entries channel="news"} {if count == 1} {layout:set name="total"}{total_results}{/layout:set} {/if} {layout:set:append name="array-title"}{title}{/layout:set:append} {layout:set:append name="array-excerpt"}{excerpt}{/layout:set:append} {/exp:channel:entries}
and then in a later template layout:
{layout:array-title limit="5"} {if count == 1} <p>Total News Articles: {layout:total}</p> {/if} <div class="news-item"> <h3>{value}</h3> <p>{layout:array-excerpt index="{index}"}</p> </div> {/layout:array-title}
HTH 🐾
User fRIQeIlu
5 months ago
Ah, forgot about the stats module
User fRIQeIlu
5 months ago
I think I’ll just use an embed @ 😉
User fRIQeIlu
5 months ago
Thanks @hopstudios - {absolute_results} works by simply adding paginate="hidden" to the parameters
{exp:channel:entries channel="news" limit="5" paginate="hidden"} {if count == 1} <p>Total News Articles: {absolute_results}</p> {/if} <div class="news-item"> <h3>{title}</h3> </div> {/exp:channel:entries}
