EE throws 404 error when creating entry
avori's avatar
avori
about 5 months ago
avori's avatar avori
Hello,
I’m using EE 7.5 and for some odd reason it started throwing a 404 error when I try to create an entry. I’m in the admin panel, hit new entry for the blog, fill it all in and when i hit save it gives me my 404 page and doesn’t save anything. Here is the path that my front end 404 pops up on .php?/cp/publish/create/4 - only happens on channel 4. All other channels work just fine.
What can be causing this issue?
Best Regards, Viktor
avori's avatar
avori
about 5 months ago
PS. I updated to the latest 7.5.16 and the issue persists.
jelle's avatar
jelle
about 5 months ago
jelle's avatar jelle
Maybe something on the hosting changed? this sounds like a mod_security issue
Rob Allen's avatar
Rob Allen
about 5 months ago
Rob Allen's avatar Rob Allen
Yes it does sound like a mod_security issue as jelle mentioned. Suggest contacting your host with the time it happend (you can always add/edit the same entry to get a precise time), they should be able to look at their logs to see if a mod_sec rule is being triggered.
Any decent host can disable any affected rules for you, in my experience you may need to disable a few rules but that depends on the server. My own host keeps a list of affected rules for EE so if other customers have the same problem they have a reference.
avori's avatar
avori
about 5 months ago
Thanks for your input everyone. I’ll reach out to them and see what they say. But for now I got it working. When I paste as plain text into the rich text editor it saves it no problem. But if I copy and paste regularly (pasting with formatting) then it throws me that error. So I’m guessing something didn’t like something, so weird. Anyway worst case scenario is I will have to reformat the text in the text editor.
Rob Allen's avatar
Rob Allen
about 5 months ago
Yes sometimes cut and paste can insert hidden data that mod_security can find suspicious, apps like MS Word can be bad for that. I always advise clients to paste into a basic text editor first, then recopy/paste into EE fields and format as required.
? 1
avori's avatar
avori
about 5 months ago
This is the first time I ran into this. I normally always copy and paste from word. But I’ll keep that in mind going forward. Thanks again.
