Can we remove pro-dashboard-widgets?
News and General
afarsh's avatar
afarsh
7 months ago
afarsh's avatar afarsh
We have recently moved from EE6 to EE7 and noticed that on a fresh install, it adds a ‘pro-dashboard-widgets’ template group along with a ‘sample-widget’. Is this something that we can remove, or does it need to be kept where it is? Thanks for any explanation - learning our way around EE7.
mithra62's avatar
mithra62
7 months ago
mithra62's avatar mithra62
You should be able to both remove it from within the dashboard settings (the little cog at the top right) and by deleting the template group “pro-dashboard-widgets” from the template manager.
afarsh's avatar
afarsh
7 months ago
Very helpful. Thank you!
