set_status_header, and send_ajax_response no longer working with 422 after upgrading from 6 to 7
benjivm's avatar
benjivm
7 months ago
benjivm's avatar benjivm
My addon has the following lines, working fine on EE 6:
$http = (new Http())
     ->withOptions(['base_uri' => ee('Config')->get('my_api').'/'])
     ->withToken(ee('Config')->get('my_token'))
     ->acceptJson();
$response = $http->post($endpoint, $data);
ee()->output->set_status_header($response->status(), $response->reason());
ee()->output->send_ajax_response($response->json(), $response->status());
Now, if the status code is 422, I receive the following on the frontend:
 "error": "No status text available.  Please check your status code number or supply your own message text."
Changing the status code to anything else works.
7 months ago
Hi Ben,
Thanks for posting this… Any chance you would be willing to try this fix?
Would be awesome if you could leave a comment on the PR if it works for you as well!
Either way we’ll aim to get this out in the next release!
-Tom Jaeger
benjivm's avatar
benjivm
7 months ago
I tested the PR and it does resolve the issue, thanks.
Can you confirm that this is unnecessary:
And all I need is this:
Or what is the preferred way of sending a payload to be consumed by a javascript frontend?
7 months ago
For those following along. This was released as part of ExpressionEngine 7.5.16
