How to define default base path and base URL during migration?
News and General
Matahi's avatar
Matahi
8 months ago
Matahi's avatar Matahi
Hi everyone,
I’m currently in the process of migrating an ExpressionEngine site (v7.5.13), and I’m not sure how to properly define the Default Base Path and Default Base URL for my environment.
When I try to set them, I keep getting the warning:
This path is either invalid or not writable.
I want to make sure my setup works for different environments (local, staging, production) without hardcoding absolute paths, but I’m not clear on the best way to configure:
Default base path (server filesystem path)
Default base URL (public URL for assets/themes)
? What’s the recommended way to set these up so the migration goes smoothly and the paths resolve correctly across environments?
Thanks in advance for any guidance!
Russ K.'s avatar
Russ K.
8 months ago
Russ K.'s avatar Russ K.
Hi.
I always do this in the config.php file.
These 2 lines will take care of it:
$config[‘base_url’] = ‘YOUR_URL’;
$config[‘base_path’] = ‘YOUR_PATH’;
Hope that helps.
R
? 1
Brian Litzinger's avatar
Brian Litzinger
8 months ago
You’ll likely want to set the variables in your config.php file, e.g.
$config['base_url'] = 'https://mysite.com/';
$config['base_path'] = '/var/www/html/public_html/';
The best option is to use the .env.php file, and set it in there:
BASE_URL=https://mysite.com/
BASE_PATH=/var/www/html/public_html/
Then your config.php would look like this, and its the most portable between environments because you can commit your config.php file to Git, and just update the .env.php file in each environment.
$config['base_url'] = $_ENV['BASE_URL'];
$config['base_path'] = $_ENV['BASE_PATH'];
There are other values that can extend those too. Setting these isn’t required, I think EE handles setting the defaults based on your base_url and base_path config, but if you do need to tweak these this is how you can do it.
$config['tmpl_file_basepath'] = $config['base_path'] . 'templates/';
$config['theme_folder_path']  = $config['base_path'] . 'themes/';
$config['theme_folder_url'] = $config['base_url'] .'themes/';
$config['captcha_path'] = $config['base_path'] . 'images/captchas/';
$config['captcha_url']  = $config['base_url'] . 'images/captchas/';
$config['emoticon_url'] = $config['base_url'] . 'images/smileys/';
$config['emoticon_path'] = $config['base_path'] . 'images/smileys/';
$config['avatar_path'] = $config['base_path'] . 'images/avatars/';
$config['avatar_url'] = $config['base_url'] . 'images/avatars/';
$config['photo_path'] = $config['base_path'] . 'images/member_photos/';
$config['photo_url'] = $config['base_url'] . 'images/member_photos/';
$config['sig_img_path'] = $config['base_path'] . 'images/signature_attachments/';
$config['sig_img_url'] = $config['base_url'] . 'images/signature_attachments/';
$config['prv_msg_upload_path'] = $config['base_path'] . 'images/pm_attachments/';
$config['prv_msg_upload_url'] = $config['base_url'] . 'images/pm_attachments/';
$config['board_upload_path'] = $config['base_path'] . 'images/forum_attachments/';
$config['board_upload_url'] = $config['base_url'] . 'images/forum_attachments/';
? 1
Matahi's avatar
Matahi
8 months ago
Thank you very much, Brian and Russ.
