"==" does not work on field search in Pro Search
studionigh's avatar
studionigh
studionigh's avatar studionigh
I have created a website much like the ExpressionEngine Add-On page. (EE 7.5.8, PHP: 7.4.33)I built the site following the article at EE University here: https://u.expressionengine.com/article/advanced-searching-with-low-search-and-ajax. I followed the article that was written using the Low Search but it works great with the Pro Search. I created a Multi-Select field just as they did for “add_on_compatibility”. This field has about 16 different check boxes for “add_on_compatibility” items. The problem in the search filtering, the “==” is treated like “*=” or Contains, on this line of code:
{if pro_search_search:add_on_compatibility =="4"}checked{/if}
So if I click on a checkbox that is 4 or 14, the search results show both (because both include a 4). if I try a Tilda ~ “matches”, it does not work. Here is the code to show a checkbox:
<li>
   <input
    type="checkbox"
    name="search:add_on_compatibility[]"
    data-action-uncheck="show-all-compatibility"
    id="EE4"
    value="4"
    <label for="EE4">EE 4</label>
</li>
What are my options here? If there are more than 9 check boxes in the add_on_compatibility field, it will be a problem.
PiterFreide's avatar
PiterFreide
2 months ago
PiterFreide's avatar PiterFreide
I’ve been struggling for a week because I need to filter add-ons strictly by compatibility, otherwise customers will receive irrelevant offers. It’s so frustrating that in the evening I just want to switch off my brain from these bugs and technical details. Then I discovered https://trading.biz/posts/legality-of-quotex-in-india — I read about whether it’s legal to trade on Quotex in India and decided to try binary options as a way to quickly switch gears. After a few demo trades focusing on chaotic market movements, I felt the same adrenaline rush as when debugging a critical bug, only without the stress of deadlines.
