kinda stuck and confused
sams's avatar
sams
sams's avatar sams
I installed EE today and set up the Forums addon but have issue where i cannot figure out how to make www.example.com to go straight to www.example.com/forums/
Russ K.'s avatar
Russ K.
Russ K.'s avatar Russ K.
I would say that if your intent is for /forums to always be the homepage, add a few lines to your .htaccess file.
RewriteEngine On
RewriteRule ^$ /forums/ [L,R=301]
should do the trick.
If you are on nGinx:
server {
    listen 80;
    server_name www.example.com;
    location = / {
        return 301 /forums/;
    location / {
        # Other configurations for your site
Hope that gets you where you need to be.
R
sams's avatar
sams
sams's avatar sams
thanks that worked 😊
sams's avatar
sams
sams's avatar sams
actually it doesnt work. it will do the redirect but will not allow members to login now.
if i remove that line i can login as a member.
sams's avatar
sams
sams's avatar sams
surely theres a way i can redirect the landing page (to https://www.example.com/forums) instead? it would be cleaner via default controller route!?!
sams's avatar
sams
sams's avatar sams
nm i got it sorted - i removed the default index template, created a new one, allowed php and just did a header redirect within.
