EE 7.5.4 Channel Images 7.6.3
Uploading image to a CI field and shows progress bar but on completion get an error…
Upload request failed, no HTTP 200 Return Code!
{"messageType":"error","message":"Call to undefined function read_exif_data()","trace":["#0 user\/addons\/channel_images\/mod.channel_images.php(1159): Channel_Images_AJAX->upload_file()","#1 ee\/legacy\/libraries\/Actions.php(181): Channel_images->channel_images_router()","#2 ee\/legacy\/libraries\/Core.php(682): EE_Actions->__construct(true, Object(Closure))","#3 ee\/legacy\/controllers\/ee.php(51): EE_Core->generate_action(true)","#4 [internal function]: EE->index()","#5 ee\/ExpressionEngine\/Core\/Core.php(269): call_user_func_array(Array, Array)","#6 ee\/ExpressionEngine\/Core\/Core.php(125): ExpressionEngine\Core\Core->runController(Array)","#7 ee\/ExpressionEngine\/Boot\/boot.php(184): ExpressionEngine\Core\Core->run(Object(ExpressionEngine\Core\Request))","#8 index.php(164): require_once('…')","#9 {main}”]}
Problem seems to only manifest with one particular field
Hello!
This is likely just php missing the exif extension or having it disabled. You can check under the cp’s tools-> PHP info for if the exif section is there and is enabled.
As for a particular field, I think exif is needed a lot more for certain file types so this might be at play, do you see this error happening on certain file formats and not on others?
