member field inside grid field, via add-on (entry model; grid model)
directordash's avatar
directordash
directordash's avatar directordash
Here is my function:
private function create_user_rows($entry, $user_count, $input_id)
     $grid_field_id = 20;
     $default_member_id = 123;
     $new_grid_data = [];
     for ($i = 0; $i < $user_count; $i++) {
         if ($i == 0) {
             // For the first row, use input_id and fetch the username
             $member_username = ee('Model')->get('Member', $input_id)->first()->username;
             $new_grid_data['new_row_' . $i] = [
                 'col_id_58' => $member_username, // Populate with the username of the author
                 'col_id_59' => $input_id,       // Set the relationship field to the author_id
                 'col_id_62' => 'unassigned',
                 'col_id_60' => 0,
                 'col_id_61' => 0
         } else {
             // For subsequent rows, use the default member_id
                 'col_id_58' => '',               // No username
                 'col_id_59' => $default_member_id,   // Default member ID for relationship field
                 'col_id_60' => 0,
                 'col_id_61' => 0
     // Load grid model to save grid data
     ee()->load->model('grid_model');
     // Save the grid data to the entry using the recommended model-based method
     $entry->{$entry->getCustomFieldPrefix() . $grid_field_id} = $new_grid_data;
     $entry->save();
     // Double-save with the grid model to ensure grid data is committed
     ee()->grid_model->save_field_data($new_grid_data, $grid_field_id, 'channel', $entry->entry_id);
col_id_59 is a member relationship field. I know that the member rel field type is typically looking for a ‘data’ array, but I feel like I’ve tried that and everything else at this point. All the other columns populate as expected; just not that one.
What am I missing?
creativearc's avatar
creativearc
creativearc's avatar creativearc
You might try asking this one in the Slack #programming channel.
https://expressionengine.com/blog/join-slack
lowalax45's avatar
lowalax45
lowalax45's avatar lowalax45
Thanks for your answer flash games. It is useful for me.
Rosariokris's avatar
Rosariokris
4 months ago
Rosariokris's avatar Rosariokris
I have been waiting for this answer for a long time papa’s freezeria
