Access State of Toggle Field in a Grid Field in Fluid Field using Field Group
stereoi123's avatar
stereoi123
stereoi123's avatar stereoi123
Hello, I’m hoping this will make some sense. How can I access the state of a toggle field within a grid field within a field group within a Fluid Field? Example of my current code below:
{fluid_field}
  {fluid_field:my_field_group}
    {fields}
    {fluid_field:my_grid}
      {content}
        {content:my_Toggle} {if {content}}Yes!{/if} {/content:my_Toggle}
      {/content}
    {/fluid_field:my_grid}
    {/fields}
  {/fluid_field:my_field_group}
{/fluid_field}
Thank you!
Bryan's avatar
Bryan
Bryan's avatar Bryan
I think you were very close! The toggle should just be use as a single tag, I did a quick test and this is working for me:
{fluid_field}
    {fields}
            {content}
                {if {content:my_Toggle}}
                    Yes!
                {if:else}
                    No.
            {/content}
    {/fields}
{/fluid_field}
? 1
stereoi123's avatar
stereoi123
Thank you, Bryan! Worked great!!
? 1
jessica101's avatar
jessica101
jessica101's avatar jessica101
thank you
clarawarren's avatar
clarawarren
clarawarren's avatar clarawarren
Gambling history spans centuries, evolving from ancient dice games to modern online platforms. For those interested in exploring themed slots, look here for Huangdi Yellow Emperor. This game blends historical elements with engaging gameplay, reflecting the rich heritage of gambling through innovative design and cultural references.
JeanWoo's avatar
JeanWoo
JeanWoo's avatar JeanWoo
You can access the state of the toggle field in the grid by checking the condition as you did in the current code. Your code is on point, just make sure that the conditional syntax is applied correctly to the “my_Toggle” field. Once done, relax and play some fun io games for fun!
