Template partials parsing empty, but not empty?
Feature Requests
directordash's avatar
directordash
directordash's avatar directordash
I am using a template partial to print a single custom member field called show_name like so:
{exp:member:custom_profile_data member_id="{logged_in_member_id}"}{show_name}{/exp:member:custom_profile_data}
I assumed, in theory, if there’s nothing in that field, the whole partial is therefore blank (assuming no spaces, line breaks, etc.) Hence, I also assumed that if the field is blank, and I run:
{if partial_name}condition{/if}
…that the condition would only print if there is something in the show_name field.
This isn’t the case though. I have tried the opposite way too by checking if the partial is blank, but I get the same result of the {if} statement believing there is still something there.
I have also tried printing the partial between two quotation marks and sure enough there is no string or value.
If this is normal behaviour, my request is to be able to check whether a rendered partial is empty or not? Equally open to alternative suggestions that allow me to do what I want to do in a reusable and resource-saving way 😊
TIA!
lisawindy907's avatar
lisawindy907
lisawindy907's avatar lisawindy907
You will learn how to create and implement a workable IDM solution from this io games book.
obscenedisgusted's avatar
obscenedisgusted
obscenedisgusted's avatar obscenedisgusted
Capture the Partial Output: Use the embed or stash approach to capture the output of the partial into a variable.
Check the Variable: Use conditionals to check if the variable is empty. Trim Whitespace: Ensure there are no hidden spaces or line breaks in your partial. You can use {trim} to remove any unnecessary whitespace: Debug Output: If you suspect there might be hidden characters, you can debug the output by printing it within quotes: By capturing the partial output and using conditionals on the variable, you can reliably check if the field is empty or not. This method ensures that any hidden whitespace or parsing quirks are handled correctly, allowing you to create reusable and resource-efficient templates.
tiny fishing
LindaClarkson's avatar
LindaClarkson
LindaClarkson's avatar LindaClarkson
Students often seek essay help to enhance their writing skills. This raises the question: why do authors use figurative language? Such techniques enrich narratives and deepen themes, proving essential in crafting compelling writing content creation that captivates and engages readers effectively.
aldenabed's avatar
aldenabed
aldenabed's avatar aldenabed
For students juggling multiple tasks, buying essays online can be a practical solution for managing academic workloads. The platform EssayPro offers a range of essay types to suit various needs, ensuring high-quality content tailored to your requirements.
Whether it’s an argumentative essay, research paper, or any other format, this service helps save time while maintaining academic standards. It’s a valuable resource for those needing extra support in handling tight deadlines or complex assignments.
Naomi Smith's avatar
Naomi Smith
10 months ago
Naomi Smith's avatar Naomi Smith
Totally relate to the frustration—when template partials appear empty but clearly aren’t, it can feel like you’re staring at a puzzle with invisible pieces. I had a similar moment recently, but in a completely different context. I was helping a friend with their economics coursework, and despite all the content being there, it just wasn’t making sense structurally—kind of like ExpressionEngine’s phantom partials!
That’s when they turned to an economics essay writing service from MyAssignmentHelp, which surprisingly mirrored the “plug-and-play” idea of working with clean, reusable templates. It made the content flow effortlessly, just like how you expect a well-parsed template to behave. Sometimes, whether it’s code or coursework, it really helps to let the experts untangle the invisible knots. Let me know if you’d like a real-world analogy or code-based comparison to build on this.
alicesphere's avatar
alicesphere
3 months ago
alicesphere's avatar alicesphere
It sounds like you’re facing a tricky issue with template partials! For checking if a rendered partial is empty, have you considered using a different approach, like a fallback value or a default message? It might help clarify when the field is truly empty. By the way, if you’re looking for some fun to take a break from coding, check out popular games for the latest and trending online games available for free!
cofffee124's avatar
cofffee124
2 months ago
cofffee124's avatar cofffee124
The biggest problem is that I love my wife and don’t want to hurt myself. She’s very insistent on this. Therefore, I have to: hide the BBW sex doll in a corner behind the furniture, otherwise part of me will never be hidden.
