Update from 3.5.17 to 7.49 Upgrade with MySQL errors
fanderson's avatar
fanderson
fanderson's avatar fanderson
The time has come to upgrade an old site.
EE: 3.5.17 MySQL 5.6 PHP 5.6
I upgraded PHP to 8.2
When I attempt to upgrade I get the following error showing in admin.php
Exception Caught
SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-20200813' at line 1:
SHOW COLUMNS FROM exp_channel_data-20200813
ee/legacy/database/drivers/mysqli/mysqli_connection.php:146
Stack Trace: Please include when reporting this error
#0 ee/legacy/database/drivers/mysqli/mysqli_driver.php(112): CI_DB_mysqli_connection->query('SHOW COLUMNS FR...')
#1 ee/legacy/database/DB_driver.php(262): CI_DB_mysqli_driver->_execute('SHOW COLUMNS FR...')
#2 ee/legacy/database/DB_driver.php(177): CI_DB_driver->simple_query('SHOW COLUMNS FR...')
#3 ee/ExpressionEngine/Library/Advisor/FieldtypeAdvisor.php(78): CI_DB_driver->query('SHOW COLUMNS FR...')
#4 ee/ExpressionEngine/Library/Advisor/FieldtypeAdvisor.php(18): ExpressionEngine\Library\Advisor\FieldtypeAdvisor->guessAllUsedFieldtypes()
#5 ee/ExpressionEngine/Library/Advisor/FieldtypeAdvisor.php(33): ExpressionEngine\Library\Advisor\FieldtypeAdvisor->getMissingFieldtypes()
#6 ee/ExpressionEngine/Library/Advisor/Advisor.php(41): ExpressionEngine\Library\Advisor\FieldtypeAdvisor->getMissingFieldtypeCount()
#7 ee/installer/controllers/wizard.php(534): ExpressionEngine\Library\Advisor\Advisor->postUpdateChecks()
#8 ee/installer/controllers/wizard.php(474): Wizard->postflight()
#9 ee/installer/controllers/wizard.php(278): Wizard->preflight()
#10 [internal function]: Wizard->_remap('do_update', Array)
#11 ee/ExpressionEngine/Core/Core.php(268): call_user_func_array(Array, Array)
#12 ee/ExpressionEngine/Core/Core.php(124): ExpressionEngine\Core\Core->runController(Array)
#13 ee/ExpressionEngine/Boot/boot.php(184): ExpressionEngine\Core\Core->run(Object(ExpressionEngine\Core\Request))
#14 admin.php(139): require_once('...')
My only options for MySQL upgrades are MySQL 5.7 or MariaDB 10.7
I need a wiser mind than mine to point me in the right direction and get this site back on its feet.
Thanks.
Hop Studios's avatar
Hop Studios
Hop Studios's avatar Hop Studios
Someone made a backup of the exp_channel_data table in 2020 (around aug 13 I bet)
And they left the extra table in your database and now it’s breaking the upgrade.
The extra table is called exp_channel_data-20200813
Make a backup of the whole database, delete that table, run the upgrade again, see what happens. Good luck!
If that doesn’t work give us a call.
TTFN Travis
? 1
fanderson's avatar
fanderson
Hi Travis,
Thank you for seeing the obvious and helping out. The upgrade went well and I can now tidy things up.
I appreciate the help.
Forrest
