Setting redirect in Detour Pro
Stoelting's avatar
Stoelting
about 2 years ago
Stoelting's avatar Stoelting
How to set up a redirect that works for second level redirect?
I have a redirect set up like this: Original: old New: new/
But I have some anchors on the page like this: old/#anchor1
A redirected page goes to page not found.
How should I set up the redirect so it includes the anchor
Rob Allen's avatar
Rob Allen
about 2 years ago
Rob Allen's avatar Rob Allen
Not sure if it works with hash symbols but you can use wildcards, so old becomes old/%
See the usage docs at https://eeharbor.com/detour-pro/documentation/usage for other wildcard methods.
? 1
troylewis's avatar
troylewis
troylewis's avatar troylewis
Hello, When setting up a redirect that includes an anchor, you need to modify the redirect configuration to include the anchor portion as well. Here’s how you can set up a redirect that works for a second-level redirect with an anchor:
Original: old/#anchor1 New: new/#anchor1
By including the full URL, including the anchor, in the redirect configuration, you ensure that the redirect takes the user to the correct page with the anchor intact.
Amanda Holden's avatar
Amanda Holden
Amanda Holden's avatar Amanda Holden
You can set up a normal redirect for the base URL. Modify links on the old page to prepend “new/” before the anchor if ExpressionEngine is running. Buildnow GG
