Having trouble using AlpineJS with ExpressionEngine.
From EE Slack's avatar
From EE Slack
about 2 years ago
Am wondering if the templating is disabling JS from being interpreted - any suggestions?
From EE Slack
about 2 years ago
Simple fix- there was an error including the library!
[script src="//unpkg.com/alpinejs" defer][/script]
But sometimes javascript can have issues if the curly brackets get taken as EE variables. Check out the config option to remove unparsed variables if the output doesn’t match what you’d expect.
fredpalmer's avatar
fredpalmer
about 2 years ago
fredpalmer's avatar fredpalmer
Thanks for your sharing solution. It helps me to solve my problem
