Upgrading from EE 3 to EE 7
Fathom's avatar
Fathom
Fathom's avatar Fathom
Hi all,
I’m trying to upgrade an old site from EE3 to EE7 and keep getting the following error that I’m unsure how to solve (shown in screenshot).
I’ve even tried to upgrade to EE5 instead of straight to 7 but still get the same error.
does anyone have any ideas?
Hi Fathom,
Thanks for getting in touch about this!
Just took a quick peek at the code that running this. I’m guessing after running the update a few times, your running into duplicate data. I’d recommend backing up your database (specifically the channels_channel_field_groups table) and then Truncating (or deleting that table) and running the update again.
Please note, I would also aim to run the updater directly to EE 7 as the updater shipped with Version 7 has significant improvements.
It may also be worth disabling extensions in via your config file
-Tom Jaeger
Fathom's avatar
Fathom
thanks for getting back to me. I’ve deleted the channels_channel_field_groups table and now i’m getting the following error:
Should I remove this table too?
Thanks for your help.
Thanks, Dan
Taking a peek at the code…
Yes.. I’d say make sure it’s backed up and then do the same with that table.
The following would also fall into this boat, if you hit them.
  • channels_channel_fields
  • channel_field_groups_fields
Again, I strongly recommend having a DB backup.
-Tom Jaeger
Fathom's avatar
Fathom
Thanks so much for your help, that all worked!
I’ve now downloaded Freeform for $149 and installed it and it works fine. However for some reason when I go to the ‘Entries’ tab, I get errors that look relevant to freeform. I don’t suppose you have any ideas?
Thanks, Dan
Hrm- first, double check that there’s an ft.freeform.php file in system/user/addons/freeform. There should be, but let’s eliminate the simple options first.
And you didn’t have Freeform (any variety) installed prior to this- correct?
