Front-end editing issues
Paul Vance's avatar
Paul Vance
about 2 years ago
Paul Vance's avatar Paul Vance
I can’t seem to get front-end editing to work on a few different sites. I’ve tried everything listed here: https://docs.expressionengine.com/v6/pro/troubleshooting.html#front-edit-links-and-dock.
All settings are enabled, I checked for console errors etc, and still can’t get it to work. Any idea what I’m missing?
about 2 years ago
Hi Paul,
Thanks for getting in touch about this.
Just to confirm. What version of ExpressionEngine are you running?
It’s also worth mentioning that front end editing also required a pro license.
-Tom Jaeger
Paul Vance's avatar
Paul Vance
about 2 years ago
Thanks Tom! 7.4.5 with a valid Pro license.
about 2 years ago
Hrmm…
Any caching enabled?
Also.. Are you accessing the site form the exact same URL as your are logging into the CP? (thinking presence of www or not..)
-Tom Jaeger
Paul Vance's avatar
Paul Vance
about 2 years ago
Yes same URL, no caching
about 2 years ago
Settings configured correctly as well?
Paul Vance's avatar
Paul Vance
about 2 years ago
Yessir - all of those are enabled.
Hop Studios's avatar
Hop Studios
about 2 years ago
Hop Studios's avatar Hop Studios
Can you verify that you’re appearing to EE as logged in when visiting the front end page you want to edit?
Paul Vance's avatar
Paul Vance
about 2 years ago
Yes I can - front end can tell I’m logged in.
about 2 years ago
Hrm- probably the first thing I’d do- turn on debugging- system- output and debug. And then reload and just skim through the template debug to see if anything jumps out.
I don’t have anything specific in mind that would indicate frontend editing, but sometimes that triggers an idea.
Paul Vance's avatar
Paul Vance
about 2 years ago
Thanks Robin - I did have a look at that, and nothing seems out of the ordinary. So weird.
about 2 years ago
Hit me in [email protected] if you can pass over access. It’s weird and looks like you’ve covered all the bases.
Paul Vance's avatar
Paul Vance
about 2 years ago
Ok done - thanks Robin!
From EE Slack's avatar
From EE Slack
Oops- circling back, we just had to get the license server spotting the right site and this was resolved.
