How to access custom fields from a channel entry in a model query.
Simon 's avatar
Simon
Simon 's avatar Simon
Hello. I have set up a channel with some custom fields. These fields do not appear with the main properties when performing a model search, they appear to be in the collection object as entities such as ‘field_id_20’. How do I perform a model search and specify a particular field as a filter in my query?
I’m hoping I can do something like: $entries = ee(‘Model’)->get(‘ChannelEntry’)->with(‘field:20’)->all();
Any help or pointers to documentation would be very appreciated.
philliprector's avatar
philliprector
philliprector's avatar philliprector
Hello @ fnaf 2, To perform a model search and specify a particular field as a filter in your query, you would need to access the appropriate model and use the available methods or syntax provided by your CMS or framework.
hoaiheo's avatar
hoaiheo
hoaiheo's avatar hoaiheo
@ fnaf 2 I completely agree with what you suggest here.
