Site Navigation
Stoelting's avatar
Stoelting
Stoelting's avatar Stoelting
Is there a plug-in that helps generate site navigation menus in EE using categories or some other means?
Justin Alei's avatar
Justin Alei
Justin Alei's avatar Justin Alei
I’d take a close look at the Structure add-on, included with EE7 (docs here). It may mean reworking some stuff on an existing project if you’ve already built everything out, but the templating can be pretty advanced.
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
You could also look at Catman - https://expressionengine.com/add-ons/catman
