Learning Twig coming from Stash
wagonheart's avatar
wagonheart
wagonheart's avatar wagonheart
I’m starting a new project and thought i’d try twig.
I’ve been using stash and one of the features i liked was setting vars in one template and accessing them in another. eg. my index templates (e.g. ‘about/index’) would just have 2 embeds {embed="_data/_main" url_title="{last_segment}"} and {embed="_templates/_view"} I set all my data in a channel entries tag in _data/_main and get that data in _templates/_view (and any subsequent embedded templates).
about/index:
_data/_main:
{exp:channel:entries channel="about" url_title="{embed:url_title}" ...}
 {exp:stash:set}
  {stash:title}{title}{/stash:title}
  {stash:entry_id}{entry_id}{/stash:entry_id}
  ...etc
 {/exp:stash:set}
_templates/_view:
<head>
<title>{exp:stash:title}</title>
</head>
<body>
<h1>{exp:stash:title}</h1>
</body>
is there a way to do this with twig? i’ve not been able to figure it out yet from the docs, wondering if anyone familiar with twig might know.
thanks
jelle's avatar
jelle
jelle's avatar jelle
Don’t really know wether that’s doable with Twig, but i think with Template Layouts you can achieve the same, without an addon and without embeds
Nelly's avatar
Nelly
Nelly's avatar Nelly
Just as jelle says, the way to do this is with Template Layouts. This video can help to get you started.
Jared Chesebro's avatar
Jared Chesebro
Jared Chesebro's avatar Jared Chesebro
I have a bunch of twig template examples in this repository: ee7-coilpack (templates)
I have found the twig implementation to be really robust and it allows you be a lot more flexible with how you build your templates. If you are new to twig you might find the flexibility confusing.
policydining's avatar
policydining
policydining's avatar policydining
Thanks a lot.
Dillan2314's avatar
Dillan2314
Dillan2314's avatar Dillan2314
When I was learning Twig after working with Stash, the transition was smoother than expected. The key was to grasp Twig’s template inheritance and logic control. If you’re tackling something complex, breaking it down with basic Twig tags first really helps. Also, while learning new syntax, don’t forget to explore resources outside coding—like improving your writing skills. For example, browsing through quality academic nursing papers examples like those on can provide clarity on structuring content effectively. This way, you enhance both coding and communication, which is essential when presenting ideas clearly in templates or documentation.
? 1
