htaccess strip "index_php?"
fensterbaby's avatar
fensterbaby
fensterbaby's avatar fensterbaby
Sorry about accidental multiple posts…I can’t even access those now
trying to strip “index.php?” from urls. It pulls out index.php but leaves “?”
I tried to include htaccess code but attempt to use markdown failed. Any files I try to attach are “not allowed”
Why can’t these post fields just be rich text fields?
DigitalSpirit's avatar
DigitalSpirit
DigitalSpirit's avatar DigitalSpirit
I would strip the htaccess code back to nothing first and then work from there. My guess is that it’s something on the server set up.
Follow the instructions here - https://docs.expressionengine.com/latest/installation/best-practices.html#removing-indexphp-from-your-urls and then once it’s working add the caching and redirects back in.
fensterbaby
Here is one thing I tried with mixed result
RewriteRule (.?)index.php/(.*) /$1$2 [R=301,NE,L]
add [QSD] to RewriteRule
RewriteRule (.?)index.php/(.*) /$1$2 [R=301,NE,QSD,L]
This strips out the query string but alas it treats everything after the ? as query string. So..
https://www.trekalaska.com/index.php?/destinations/denali-state-park
becomes
without the [QSD] it becomes
https://www.trekalaska.com/?/destinations/denali-state-park
query string disabled in CP
These links are old one that Google still checks so produces errors. Links with index.php not being generated by current site
Hop Studios's avatar
Hop Studios
Hop Studios's avatar Hop Studios
Try this:
RewriteRule ^index.php$ %{QUERY_STRING} [R=301,NE,QSD,L]
This should match https://www.trekalaska.com/index.php?/destinations/denali-state-park
and return https://www.trekalaska.com/destinations/denali-state-park
Note that it will match ONLY index.php, not any sub-path, and also that if the query string has more fluff than just the EE segments, that’ll still be appended after the rewrite, which might not be what you want.
…I used this to help: https://htaccess.madewithlove.com/
fensterbaby
OMG- that’s it!
Seems to be working perfectly. I have tried soooo many times to fix this. You are the first with a solution that works as intended.
Thanks for your help!
fensterbaby
I spoke too soon :-(
returns
which is perfect
However… https://www.trekalaska.com/index.php/destinations/denali-state-park
Returns https://www.trekalaska.com/index.php/destinations/denali-state-parks
and a 404 error
It strips out “index.php?” But not “index.php”
Also, a URL like https://www.trekalaska.com/?/destinations/denali-state-park
outputs no change and a 404
so am trying to strip out any of the following
“index.php” - “index.php?” - “?”
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
Have you removed index.php from Settings > URL and Path Settings
https://docs.expressionengine.com/latest/control-panel/settings/urls.html#website-index-page
fensterbaby
Yes. That was removed in settings.
It’s getting rid of “index.php?” or “?” that is a problem
https://www.trekalaska.com/index.php?/alaska-hiking-trips/wrangell-st-elias-national-park
redirects to…
https://www.trekalaska.com/?/alaska-hiking-trips/wrangell-st-elias-national-park
Wavicujjoys's avatar
Wavicujjoys
Wavicujjoys's avatar Wavicujjoys
Stripping “index.php?” from URLs To remove “index.php?” from your URLs using .htaccess, you can use the following code:
RewriteEngine On RewriteCond %{REQUEST_URI} ^/index.php\?(.)$ RewriteRule ^index.php\?(.)$ /$1 [R=301,L]
This should redirect any URL containing “index.php?” to the clean version without it. geometry dash meltdown
