.htaccess file - stripping out "index_php?"
fensterbaby's avatar
fensterbaby
fensterbaby's avatar fensterbaby
My htaccess code removes “index.php” from urls but it’s supposed to strip out “index.php?”
it leaves the ? which produces a 404 error. htaccess coding is way beyond me
here is my code:
RewriteOptions inherit
DirectoryIndex   index.php index.html
# Redirects #
# Redirect 301 /alaska-wrangell-skyscraper.html https://www.trekalaska.com/alaska-hiking-backpacking-trips/wrangell-skyscraper-traverse
# Caching #
Header unset Pragma
FileETag None
Header unset ETag
#1 Year
<FilesMatch "\.(jpg|jpeg|png|gif|swf|flv|ico)$">
Header set Cache-Control "max-age=31556926, public"
</FilesMatch>
#1 Month
<FilesMatch "\.(js|css)$">
Header set Cache-Control "max-age=2629743, public"
</FilesMatch>
#1 Week
<FilesMatch "\.(html|htm|txt|php)$">
Header set Cache-Control "max-age=604800, public"
</FilesMatch>
# Compression #
<IfModule mod_deflate.c>
AddOutputFilterByType DEFLATE text/html text/xml text/css text/plain
AddOutputFilterByType DEFLATE image/svg+xml application/xhtml+xml application/xml
AddOutputFilterByType DEFLATE application/rdf+xml application/rss+xml application/atom+xml
AddOutputFilterByType DEFLATE text/javascript application/javascript application/x-javascript
AddOutputFilterByType DEFLATE application/x-font-ttf application/x-font-otf
AddOutputFilterByType DEFLATE font/truetype font/opentype
</IfModule>
<IfModule mod_security.c>
SecFilterEngine Off
SecFilterScanPOST Off
</IfModule>
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteBase /
    # Removes index.php from ExpressionEngine URLs
    RewriteCond %{THE_REQUEST} ^GET.*index\.php [NC]
    RewriteCond %{REQUEST_URI} !/system/.* [NC]
    RewriteRule (.*?)index\.php/*(.*) /$1$2 [R=301,NE,L]
    # Directs all EE web requests through the site index file
</IfModule>
# Enable Compression
  AddOutputFilterByType DEFLATE application/javascript
  AddOutputFilterByType DEFLATE application/rss+xml
  AddOutputFilterByType DEFLATE application/vnd.ms-fontobject
  AddOutputFilterByType DEFLATE application/x-font-opentype
  AddOutputFilterByType DEFLATE application/x-font-otf
  AddOutputFilterByType DEFLATE application/x-font-truetype
  AddOutputFilterByType DEFLATE application/x-javascript
  AddOutputFilterByType DEFLATE application/xhtml+xml
  AddOutputFilterByType DEFLATE application/xml
  AddOutputFilterByType DEFLATE font/opentype
  AddOutputFilterByType DEFLATE font/otf
  AddOutputFilterByType DEFLATE font/ttf
  AddOutputFilterByType DEFLATE image/x-icon
  AddOutputFilterByType DEFLATE text/css
  AddOutputFilterByType DEFLATE text/plain
</IfModule>
<IfModule mod_gzip.c>
  mod_gzip_on Yes
  mod_gzip_dechunk Yes
  mod_gzip_item_include file .(html?|txt|css|js|php|pl)$
  mod_gzip_item_include handler ^cgi-script$
  mod_gzip_item_include mime ^text/.*
  mod_gzip_item_include mime ^application/x-javascript.*
  mod_gzip_item_exclude mime ^image/.*
  mod_gzip_item_exclude rspheader ^Content-Encoding:.*gzip.*
</IfModule>
# Leverage Browser Caching
<IfModule mod_expires.c>
  ExpiresActive On
  ExpiresByType image/jpg "access 1 year"
  ExpiresByType image/jpeg "access 1 year"
  ExpiresByType image/gif "access 1 year"
  ExpiresByType image/png "access 1 year"
  ExpiresByType text/css "access 1 month"
  ExpiresByType text/html "access 1 month"
  ExpiresByType application/pdf "access 1 month"
  ExpiresByType text/x-javascript "access 1 month"
  ExpiresByType application/x-shockwave-flash "access 1 month"
  ExpiresByType image/x-icon "access 1 year"
  ExpiresDefault "access 1 month"
</IfModule>
<IfModule mod_headers.c>
  <filesmatch "\.(ico|flv|jpg|jpeg|png|gif|css|swf)$">
  Header set Cache-Control "max-age=2678400, public"
  </filesmatch>
  <filesmatch "\.(html|htm)$">
  Header set Cache-Control "max-age=7200, private, must-revalidate"
  </filesmatch>
  <filesmatch "\.(pdf)$">
  Header set Cache-Control "max-age=86400, public"
  </filesmatch>
  <filesmatch "\.(js)$">
  Header set Cache-Control "max-age=2678400, private"
  </filesmatch>
</IfModule>
# RewriteEngine On
# RewriteCond %{HTTP_HOST} ^trekalaska.com [NC]
# RewriteRule ^(.*)$ https://www.trekalaska.com/$1 [L,R=301]
# Permanent URL redirect - generated by www.rapidtables.com
Redirect 301 /trips/alaska-wrangell-skyscraper.html https://www.trekalaska.com/alaska-hiking-backpacking-trips/wrangell-skyscraper-traverse
Redirect 301 /alaska-hiking-backpacking-trips/seven-pass-route-iceberg-lake-to-bremner https://www.trekalaska.com/alaska-hiking-backpacking-trips/seven-pass-route-iceberg-to-bremner
Redirect 301 /index.php?/trips/alaska-wrangell-skyscraper.html https://www.trekalaska.com/alaska-hiking-backpacking-trips/wrangell-skyscraper-traverse
Redirect 301 /alaskas-wrangell-st.-elias-national-park/kennicott-alaska https://www.trekalaska.com/wrangell-st-elias-national-park/kennicott-alaska
Redirect 301 /index.html https://www.trekalaska.com
# php -- BEGIN cPanel-generated handler, do not edit
# Set the “ea-php80” package as the default “PHP” programming language.
<IfModule mime_module>
  AddHandler application/x-httpd-ea-php80___lsphp .php .php8 .phtml
</IfModule>
RewriteCond %{HTTP_HOST} ^.*$
RewriteRule ^alaska\-hiking\-backpacking\-trips\/seven\-pass\-route\-iceberg\-lake\-to\-bremner$ "https\:\/\/www\.trekalaska\.com\/alaska\-hiking\-backpacking\-trips\/seven\-pass\-route\-iceberg\-to\-bremner" [R=301,L]
DuBose Web's avatar
DuBose Web
DuBose Web's avatar DuBose Web
Do you have force url query strings turned on?
Docs: https://docs.expressionengine.com/latest/general/url-structure.html#query-strings
If so, I recommend turning it off.
? 1
jaimeramirez's avatar
jaimeramirez
jaimeramirez's avatar jaimeramirez
Hello @ uno online To modify the code to strip out “index.php?” and keep the query string, you can make the following changes:
apache <IfModule mod_rewrite.c> RewriteEngine On RewriteBase /
RewriteCond %{THE_REQUEST} ^GET.*index\.php\? [NC]
RewriteRule ^index\.php$ / [R=301,NE,L]
</IfModule>
With these changes, the htaccess code will redirect URLs with “index.php?” to the root URL without the query string. Please note that modifying htaccess files can be complex, and it’s recommended to have a backup and test thoroughly after making any changes.
neha's avatar
neha
neha's avatar neha
Hey hi, please remove index_php? from URL in your .htaccess file. ex,
RewriteRule ^(.*)index\.php$ /$1 [R=301,NE,L]
With the help of Redirect Checker, you will be able to track the chain of redirects to which your page redirects. It is advisable to set up redirects on the site in such a way that there is only one redirect between the start and end URL.
