Having trouble using .env files with EE
From EE Slack's avatar
From EE Slack
I’m currently trying to setup ExpressionEngine to run off environment files as per the documentation. I seem to be having trouble getting my config file to pickup the .env.php settings on my install.
Anything specific I should do?
From EE Slack
Your .env.php file currently needs to be to be in the same directory as your index.php file for the site.
David O'Neill's avatar
David O'Neill
David O'Neill's avatar David O'Neill
That is not my experince. I have my .env.php at the same level as my system directory. I can then access any value, for example MY_ENV_VALUE=test in my config files by using $_ENV[‘MY_ENV_VALUE’]
What is really cool is that you can inject that into the config object $config[‘custom_value’] = $_ENV[‘MY_ENV_VALUE’]; and then reference that in your custom add on code like this ee()->config->item(‘custom_value’).
This kind of pattern makes multi environment setups a breeze. You can die and dump $_ENV at the top of your config file to ensure you are getting what you expect.
