SEO Lite (pro) ---- home page fields not updating
fensterbaby's avatar
fensterbaby
fensterbaby's avatar fensterbaby
EE 7.3.14 SEO Lite 2.2.2
Seems to be working except on home page.
Some field values show up and some don’t. Have edited the fields but changes never show up on output page.
Not a cache issue. Cache add-on turned off and cleared browser cache times… several times.
Jared Chesebro's avatar
Jared Chesebro
Jared Chesebro's avatar Jared Chesebro
What does your template tag look like? I usually use the entry_id as it’s more reliable:
{exp:seo_lite entry_id="{entry_id}"}
fensterbaby
That’s the tag I am using as well.
Jared Chesebro
And it’s within your {exp:channel:entries} loop?
fensterbaby
no it’s in the head section between {exp:seo_lite entry_id="{entry_id}”} {/exp:seo_lite } tags.
Doesn’t need to be in an entries loop.
it’s working except for the home page for which it seems to be using the default values from settings. The entry fields are ignored. but only home page
fensterbaby
okay, guess it does need to be in an entries loop.
Jared Chesebro
Especially for the homepage because it doesn’t have a url segment to use as a fallback for the entry_id.
Since you can only get the entry_id within a loop and there’s no url segment then it’s falling back to your default values.
fensterbaby
Yeah got it. thanks for your help!
smithloo's avatar
smithloo
smithloo's avatar smithloo
just check head section and site structure bro
