A feature or an addon to display the entries
News and General
Thearegaven's avatar
Thearegaven
Thearegaven's avatar Thearegaven
Is there a feature or an addon to display the entries that are using a particular file? Like if I click an image file in a file directory I’m able to see which entries are using it and their links?
DuBose Web's avatar
DuBose Web
DuBose Web's avatar DuBose Web
If your ExpressionEngine install is up to date, there is a feature built into File Manager called “usage”. That allows you to mostly see where images are being used. I’m not sure that it will work with every fieldtype though. I think it only works with native file fields.
Here’s a demo of the usage feature: https://www.youtube.com/live/vnEtTUME2b4?feature=shared&t=1025
obviouslyadequate's avatar
obviouslyadequate
obviouslyadequate's avatar obviouslyadequate
I remember having this feature. Let me find it again and see where it is
We also just covered this in a recent Tuesday Tips with Tom.
File Usage
