Hi. I’m using a site/_wrapper layout template and, pushing data using layout:set from the parent template (site/index). For example:
{layout="site/_wrapper"}
{layout:set name="body_class"}{template_group} {template_name}{/layout:set}
{exp:channel:entries channel="pages" disable="categories|member_data|pagination"}
{layout:set name="meta_title"}{title}{/layout:set}
<h1>{title}</h1>
{/exp:channel:entries}I am getting an issue where the body_class variable passes through fine but the meta_title one inside the entries tag does not. The title does display so the entries tag is returning data. The debug actually lists the meta_title one under undefined variables in this scenario. I’ve also tried test data with the meta_title one outside the entries tag to check the variable was correct and that does pass data through.
If I reverse it round so the entries tag is inside the layout:set like this…
{layout:set name="meta_title"}{exp:channel:entries channel="pages" disable="categories|member_data|pagination"}{title}{/exp:channel:entries}{/layout:set}…then that does pass the variable data. So it looks like the layout:set tags are not being processed inside the entries tag.
This is using EE 7.3.14 on PHP8.2. I came across this issue running it on MAMP on my local system but have since set it up on a live server and I’m still getting the same issue.
Is there a bug in this version or have I missed something?
Thanks for any help.
Hi there. Did you try changing the layout variable name? Like maybe “meta_title_custom” or something like that? I usually find when I have one variable that works and another that doesn’t it is because of clashing variable names.
Hope thats of some help.
One other thing… You CAN set layout tags within a Channel Entries tag pair, but I think only if you are expecting only a Single entry to be returned. If there are more than a single entry you may need to look at {layout:set:append} tags.
Thanks Russ. I’ve tried renaming but still no joy. That entries tag should only have a single entry (I’ve got limit=”1” and require_entry set on it now on the actual template). I’ve often used this approach to push meta data and other information based on the entry’s content to a wrapper template so I can customise the display so it’s a bit strange why it’s not working this time.
Just to confirm, this is the full code in the index template so far:
{!-- <!-- Template: site/index || Home --> --}
{layout:set name="breadcrumb"}<a href="http://{path=contact}">Contact us</a>{/layout:set}
{exp:channel:entries channel="pages" entry_id="2" disable="categories|member_data|pagination" dynamic="no" limit="1"}
{layout:set name="meta_title_custom"}{title}{/layout:set}
{layout:set name="meta_description"}{meta_description}{/layout:set}
{layout:set name="meta_custom"}{meta_custom}{/layout:set}
<!-- other field content to be added -->
{/exp:channel:entries}…and then the _wrapper template:
{!-- <!-- Template: site/_wrapper --> --}
<!doctype html>
<html>
<head>
<meta charset="{charset}">
<title>{layout:meta_title_custom} | {site_name}</title>
<link rel="stylesheet" href="{stylesheet=site-css/nium-core.css}">
</head>
<body class="{layout:body_class} {layout:title_section_class}">
<a href="#main" class="skiplink">Jump to content</a>
<div class="site-outer">
<div class="site-content">
<header id="header" class="site-header">
<div class="site-header-inner">
<div class="site-title"><a href="http://{homepage}">{site_name}</a></div>
<nav id="nav" class="site-nav">
<input id="display_nav" type="checkbox" value="y">
<label for="display_nav"><span>Show navigation menu</span></label>
<div id="nav_menu" class="menu"><!-- menu to go here --></div>
</nav>
{if layout:breadcrumb}<div class="breadcrumb">{layout:breadcrumb}</div>{/if}
</div>
</header>
<main id="main" class="site-main">{layout:contents}</main>
<footer id="footer" class="site-footer"></footer>
</div>
</div>
</body>
</html>I’ve include a screenshot of the variables info from the debug where you can see the meta_title_custom is undefined (title_section_class is one that will be added for layout options but I’m having the same issue with that when trying to use it in an entries tag).
