Problem displaying Layout title
Matahi's avatar
Matahi
Matahi's avatar Matahi
When I try to display the title of a layout (layout:title) in a template and the original entry is titled with a number less than 3 digits, it is blank. Only if I include a letter in the title or the title is greater than three digits does it appear correctly.
Does anyone know why?
JCOGS Design's avatar
JCOGS Design
It would help you get a faster / more complete reply if you could:
  • Provide information about the version of ExpressionEngine you are using
  • Provide some information about the hosting environment being used (e.g. php version, server type)
  • Provide an example of the template tag that you are having difficulty with
Matahi's avatar
Matahi
Of course, JCOGS. I am using the 7.3.14 version of EE running on the 8.24 version of XAMPP.
{exp:channel:entries channel="films" require_entry="no" dynamic="yes" limit="1"} {layout:set name='title'}{title}{/layout:set} {/exp:channel:entries}
Thnx.
Russ K.'s avatar
Russ K.
Russ K.'s avatar Russ K.
Hi Matahi, Just to confirm, you are using a layout variable with a layout Template and not trying to call it inside the same file. Correct?
General page to page_layout structure should be:
For the page:
{layout="_layouts/_my_page_layout"}
In the page “_layouts/__my_page_layout” :
{layout:title}
R
Matahi's avatar
Matahi
That is correct, Russ K. I am not trying to call it inside the same file.
Thnx
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
What happens if you rename the parameter to something unique, e.g.
{layout:set name='page-title'}{title}{/layout:set}
and use {layout:page-title} in your layout template.
JCOGS Design
I have been unable to replicate on my local system (EE7.3.14, php 8.1). What happens if you try some variations - do you get a result when you use this tag (for example)?
    {layout:set name='title'}x-{title}{/layout:set}
and then in the template where you retrieve the value
{layout:title:replace find="x-" replace=""}
Would be interesting to know if it makes any difference. ?
Matahi's avatar
Matahi
Renaming the parameter to something unique nor using another tag does not work either.
I am pretty sure the problem is the title. Using a a two or three digits title instead a combination of letters and numbers. ?
