Installing Add-Ons in EE7
avori's avatar
avori
avori's avatar avori
Hello, I’m trying to install an addon that was initially intended for an older version of EE but it is compatible with EE7. So it has a folder that needs to be added to user/addons and a folder that needs to be added to users/themes. I can’t find a themes folder in my system folder.
JCOGS Design's avatar
JCOGS Design
The themes folder referred to is usually within the web root folder (typically called something like public_html). Within that folder you will find two sub-folders - ee and user - the theme folder you are trying to install needs to be placed within the user folder HTH ?
? 1
avori's avatar
avori
Thank you so much!
Humorstoo's avatar
Humorstoo
Humorstoo's avatar Humorstoo
the themes folder you’re looking for is typically located within the web root folder, not inside the system folder. The web root folder is often named something like public_html. Inside this folder, you should find two sub-folders: ee and user. The theme folder from your addon should be placed within the user folder.
@Uno Online
