Ckeditor Upgrade to Premiun?
ctw's avatar
ctw
ctw's avatar ctw
Is there a path for us to upgrade the native Ckeditor5 to premium?
Thanks in advance!
Russ K.'s avatar
Russ K.
Russ K.'s avatar Russ K.
Hi ctw, I believe the answer to that is no. I only say that because I haven’t heard any mention of it on Slack nor is there anything about it in the Docs, nor is there anyplace for that in the RTE Add-on settings in the CP.
R
Hi CTW,
Are there specific premium items you would like to take advantage of?
-Tom Jaeger
