Does Expression Engine support integration with HubSpot?
DB47's avatar
DB47
DB47's avatar DB47
If not, I assume that the only way I can utilize HubSpot is by adding a form to the Expression Engine website using a shortcode or embed code.
If anyone has any insight to pass along on this topic it would be superhelpful!
Thank you in advance!
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
The Freeform addon has a Hubspot integration - https://expressionengine.com/add-ons/freeform
Russ K.'s avatar
Russ K.
Russ K.'s avatar Russ K.
To be honest, I haven’t done it in years, but the last time I did this with EE it was as simple as installing the embed code and utilizing HubSpot forms, however, I recall there being a way to use the EE forms and inject hubspot code into it so you could style to match your site easier. (although you could with Hubspot as well)
As I recall, I had all the Hubspot functionality. Most CRMs have good functionality to integrate their code into other CMSs just because if they didn’t, they’d lose out on a lot of opportunity. Not everyone wants to use the HubSpot page builder for their sites.
