Template Partial does not work on a single-entry page
obadoba's avatar
obadoba
obadoba's avatar obadoba
Hi All,
I have a few channels for my website, the main channel (channel1) and another channel (channel2).
I’m using a sidebar in my channel1 templates which shows the titles of channel2. I set up the sidebar in a Template Partial.
The Partial displays the titles fine on the index-page of channel1 (where a number of entries are shown) but does not display on a single-entry-page (where just one entry of the channel1 is shown).
I tried using an embedded template with the titles of channel2 as sidebar. It displays fine by itself and displays fine on the index-page, but also does not display the titles on the single-entry-page.
Why does my Partial or the embedded template not display on the single-entry-page?
The Partial looks like this:
{exp:channel:entries channel="channel2" category="4" sort="desc" limit="5" disable="member_data|trackbacks"}
<div>{title}</div>
I use it on the index-page like this:
<div id="sidebar">
{template}
</div>
{exp:channel:entries channel="channel1" sort="desc" limit="5" disable="member_data|trackbacks"}
<div><a href="{title_permalink=channel1/single}">{title}</div>
I use it on the single-entry-page like this:
<div id="sidebar">
{template}
</div>
{exp:channel:entries channel="channel1" limit="1" disable="member_data|trackbacks"}
<div>{title}</div>
Any hints why this is not working as exprected are very appreciated!
Cheers, Andrea
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
In your partial entries tag add the parameter dynamic=”no”…
{exp:channel:entries channel="channel2" category="4" sort="desc" limit="5" disable="member_data|trackbacks" dynamic="no"}
<div>{title}</div>
obadoba's avatar
obadoba
That did the trick 😊 Thank you so very much, this cost me me hours and hours of headache.
