How to change the channel that an entry is assigned to?
Flacksmith's avatar
Flacksmith
Flacksmith's avatar Flacksmith
It seems like I used to be able to select an entry in the entries list, and change or edit the channel from the dropdown selector? It’s been a while. There’s got to be a way to do this … right?
Russ K.'s avatar
Russ K.
Russ K.'s avatar Russ K.
Hello, It is easy to do as you suggested, however, the one caveat to that is that the channels must be identical - or at least, all the fields available in the original entry’s channel, must be available in the new one.
R
Hop Studios's avatar
Hop Studios
Hop Studios's avatar Hop Studios
Also, the category groups assigned to both channels must be the same. And, used to be that the Statuses assigned to both had to be the same, but I’m not sure if that is also still required.
TTFN Travis
Kate Bishop's avatar
Kate Bishop
Kate Bishop's avatar Kate Bishop
ExpressionEngine doesn’t currently allow changing an entry’s channel directly through the entry list dropdown selector anymore. You can utilize the Channel Entries tag with specific parameters to achieve a similar effect. This Wordle Unlimited method is more suited for programmatic changes or specific scenarios.
