Commenting for this entry has expired
NeilC's avatar
NeilC
NeilC's avatar NeilC
I’m not sure when it started, maybe after upgrading to 6.4.11, but all of my blog posts are now showing the “Commenting for this entry has expired” message at the bottom. Comments previously made are still being displayed, though the most recent comment is from 2019 (4 years ago). It’s never been a very active website for comments, so that isn’t all that startling, but it could mean that the issue has been around for longer than I realized.
In the control panel, the comment module is enabled. I don’t know where else to look for the issue. Can anyone suggest how to fix this?
Nelly's avatar
Nelly
Nelly's avatar Nelly
Check the channel’s settings (Channels > your channel that is presenting that problem > Settings).
Scroll to Commenting, and see if Comment expiration is set to 0.
NeilC's avatar
NeilC
Thank you. The Comment expiration is set to 0, but I found that Allow comments was disabled for the whole channel, which was why I didn’t see a setting for that in the individual entries. Now that I’ve enabled it for the channel, I can go back and enable it for the individual entries.
I must have disabled it a while back when I was getting too much spam. I’ll have to hope that the spammers have forgotten about me, or find some sort of spam prevention add-on.
Nelly's avatar
Nelly
It’s been a while since I enabled comments for any sites, but in that time, I just added the native EE Captcha.
The Hinder add-on is pretty neat too, and super cheap.
NeilC's avatar
NeilC
Thanks. I’ve added the captchas, and also activated the Spam add-on for good measure. Fingers crossed.
timothyferriss's avatar
timothyferriss
timothyferriss's avatar timothyferriss
If you’re using any plugins or themes related to comments or post management, they might be causing conflicts or overriding default settings. Try deactivating plugins backpack battles one by one to see if any particular one is causing the issue.
Vahinope's avatar
Vahinope
Vahinope's avatar Vahinope
Check that the blog geometry dash lite version on your platform is the latest version. Ascertain whether your dashboard’s comments feature is activated. To ensure that there are no limitations on adding new comments, double-check your comment settings.
tommchris's avatar
tommchris
tommchris's avatar tommchris
With its innovative fusion of kinetic energy and strategy, kinitopet represents the cutting edge of gaming technology.
drebitto9's avatar
drebitto9
drebitto9's avatar drebitto9
It seems like your blog is experiencing a dreadhead parkour of its own! Have you tried checking the settings in your blogging platform to see if there’s an option to extend the commenting period? Sometimes, these settings can be a bit hidden, so it might be worth exploring. If that doesn’t work, reaching out to their support team could help unravel this comment mystery!
Anyana's avatar
Anyana
2 months ago
Anyana's avatar Anyana
Winter is here, and your sled is ready in snow rider 3d! snow rider 3d
