Updated image is not refreshing
News and General
scottb's avatar
scottb
scottb's avatar scottb
I have an image that is updating on a regular basis. I’m pulling it onto a template from an external directory. The image on the template is not updating even though I have turned off cache on the template. How do I get the image to update?
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
It could be your browser caching the image. Suggest doing a hard refresh of the page or clearing your browser cache.
scottb's avatar
scottb
Thanks for the suggestion. Unfortunately, there is no change.
Rob Allen's avatar
Rob Allen
Ok, try changing the image called from the template and get that to load, then change back to the original image to see if it picks it up.
scottb's avatar
scottb
I figured out the problem. The image file is not overwriting at the source. Thanks for your help!
Rob Allen's avatar
Rob Allen
aha that did cross my mind! glad you got it sorted.
